I get memory issue messages while communicating to a serial card using Labview calls to a DLL.
Hi all,
Using a PXI-8176 controller, I more than often get a "reference memory could not be read" or "Labview memory is full" message when communicating to a ATC-SCC serial card (Transmit line looped back to Recieve line) through a third party DLL that runs well on its own.
This message usually occurs when I have the call DLL function node in a continuous loop but is not consistent as to which loop iteration it occurs in. It seems to happen when a Recieve request is made.
I have configured the call library node to Re-entrant. The DLL is specified to autosize the associated FIFO buffers but at this stage of development I am transmitting small amounts of data (18 - 1
80byte strings) before performing the Recieve operation which sometimes works OK.
Using Labview7 on Win2000 OS the task manager indicates memory usage of 135Mb with the program running. I am soon upgrading from 128Mb to 256Mb SDRAM but have my doubts if it will work since I tried increasing virtual/shadow memory to 300Mb (task manager then shows usage at 135Mb/300Mb).
The serial card is an Alphi Techology Corporation product; Quad channel Serial Comms Controller supproting RS232/422/485.
I have also read the discussion thread from Frenk (03/18/2004) - I suspect the DLL I use does not perform a CLEAR operation after its calling subvi finishes executing. Is this of significant impact??
Any advice please?
Many thanks in advance.
Kenos
(2,617 Views)
You need to provide the DLL function prototype and your call DLL node within it's vi in order to be of futher help. I suspect that it is the setup of the call. If you are returning the message from the call in a str *, the string buffer must be allocated in LabVIEW and be filled in by the DLL.
Stu
(2,617 Views)
Thanks alot for your help. Your suggestion was the solution - when I found out how to allocate the string buffer memory in LabV I didnt get the error.
Many thanks again.
For any others out there I found out how to do this in C:\Program Files\National Instruments\LabVIEW 7.0\examples\dll\data passing\Call DLL.vi; selected CHAR and pressed "Open example vi...." button.
(2,617 Views)
