 gpsrt
			gpsrt
			06-21-2009 11:57 PM
I want to access a called vi from the calling vi.I've attached the vi here.In the program, if the condition is true a vi that we specify should be opened.It is of great help if anyone can modify it.
 altenbach
			altenbach
			06-22-2009 02:06 AM
Well, just place the icon of the desired subVI in taht case structure and configure it to show the front panel when called.
Anyway, you should probably start with a few simple tutorials, because your code does not make a lot of sense. What is the purpose of the while loop? Why do you use the stop function? Your VI will run immediately and will fail before the user has a chance to enter username and password.
 jcarmody
			jcarmody
			06-22-2009 05:31 AM
This ought to get you started. Ask away if you have any questions.
 Robin Hood
			Robin Hood
			06-22-2009 05:49 AM
can I use "This vi".If so How can I go about it?
 jcarmody
			jcarmody
			06-22-2009 07:01 AM
