accessing called vi from the calling vi
     I want to access a called vi from the calling vi.I've attached the vi here.In the program, if the condition is true a vi that we specify should be opened.It is of great help if anyone can modify it.
kiranmayi
(2,863 Views)
Well, just place the icon of the desired subVI in taht case structure and configure it to show the front panel when called.
Anyway, you should probably start with a few simple tutorials, because your code does not make a lot of sense. What is the purpose of the while loop? Why do you use the stop function? Your VI will run immediately and will fail before the user has a chance to enter username and password.
(2,842 Views)
Duplicate post
This ought to get you started.  Ask away if you have any questions.
Jim
(2,827 Views)
can I use "This vi".If so How can I go about it?
Regards
RobinHood
(2,820 Views)
You sure can use that VI; it's attached to the post.
Jim
(2,811 Views)
