accumulated timer with multiple starts and stops
I Know this is probably a duh moment, but I need to create a timer that when an I/O state goes true keeps track of seconds and when the I/O state goes false stops the timer but keeps the seconds and adds it the new seconds when the timer starts again.
So this is an accumulated timer with multiple starts and stops (In ladder logic I would just use an accumulated timer, turn it on and off).
I like the idea of using the “Elapsed time” but I need some way to store the seconds and not be reset to zero when the timer stops. Ive tried “loop back nodes” but need some way to isolate it so it doesn't see the reset zero. Or maybe theirs a better way. The solution just keeps hiding from me.
I have multiple NI 9421’s talking via eNet to LabView 2010 on Windows7, reading boolean states with single channel lines from DAQ Assist. 24 cnc machines, reading 4 different on/off states each. I want to know how long each machine has been on and/or off in each state, accumulative.
Eventually displaying on a monitor each state like a semaphore, and recording to a file for future use, but I think I have that part worked out. Any help would greatly be appreciated.
(2,797 Views)
Accepted by topic author dchris22
A shift register and a case structure are the keys to accumulating things conditionally.
The example attached accumulates counts rather than time. It adds to the count when the random value is greater than 0.8.  For time accumulation I would either use Tick Count or Get Current Date/Time and subtract the current value from the previous value. Add the differenc to the cumulative total.
Lynn
(2,779 Views)
