acquire signals from different channels with different sampling rate at the same time
Is it possible to acquire signals from different channels with different sampling rate at the same time? The DAQ device I have is PCI6221 (M Series). Is there any example code available?
Help!
(3,292 Views)
Most NI DAQ boards have only one subsystem for timing analog inputs.  So you can't use separate clocks on separate channels.  You should sample all of your channels at the fastest rate, and throw away the data you don't need.
(3,283 Views)
Additionally,
Although it is not possible with hardware timed acquisition.
You can do something like this by using software timing and acquire different channels at different rates
Look at attached vi
(3,269 Views)
Sorry, can you change it to a lower version? I only have LabVIEW 7.1
(3,251 Views)
In LabVIEW 7.1
Message Edited by devchander on 09-07-2007 04:15 AM
(3,233 Views)
If you really need different sample rates, the best solution is to use two DAQ boards.  Then you can set the sample rate differently for each board.
- tbob
Inventor of the WORM Global
(3,212 Views)
