acquiring signal using DAQmx 6221
I'm new to using DAQ. I need some pointers on how to go about the following
issue. I want to acquire a sine wave through DAQmx (PCI 6221). I need to
acquire the signal at a particular rate and store it as a binary and ASCII
file. Also I want to know how to output a signal through DAQmx. Could you
please give some pointers and example VIs if any?
Sukanya
(2,504 Views)
Go to Help>Find Examples. Then expand Hardware Input and Output>DAQmx. Also look at Getting Started With DAQmx.
(2,498 Views)
