acquisition with USB-6259
Hello everybody,
I use the example here with NI USB-6259 BNC.
It has intermal clock working at 80MHz.
1)Do I understand that right and it should provide a time accuracy up to 12.5ps?
I want to use external digital signal at 500kHz to trigger acquisition into 2 analig channels (voltage).
Channel 1 should sample with a delay after trigger, adjustable within 0.5us-1.5us.
Channel 2 should sample with a different delay after trigger, adjustable within 1.5-2us.
2) Is that doable with  NI USB-6259 and standart DAQmx functions?
3) Can someone suggest a link to an example?
Thank you in advance,
Alex
(2,935 Views)
You are trying to acheive a triggered acquisition with strict timing constraints.
It can be acheived by Daqmx
Have a look into : Cont Acq Sample-Timed Loop-Analog Start.vi in the examples shipping with LabVIEW and post back for queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,913 Views)
Dear JK1,
I have tried the example and can not get it running. Error msg attached.
What I do:
1.In this example sampe clock rate is 1kHz. I leave it unchanged just to try, but I would like to go up to 1MHz 🙂
2. I connect trigger voltage (0-5V, 250kHz)  to  PFI0 and  APFI0 on  NI-USB6259
3. I connect sync 0-1V 250kHz signal to ai0
4. I make corresponding changes to channels in the example and try different trigger and timing parameters.
Nothing helps. What do I do wrong?
thanks
(2,898 Views)
