activate menu on left click
Dear all, Is there a way to activate the run time menu on left click also and not just on right click ? Thanks, Ritesh
(2,918 Views)
Sure. Just handle Mouse Down? Event where you can "swap" buttons.
"Quick and dirty" implementation in attachment.
Andrey.
(2,911 Views)
Accepted by LVCoder
Hi Ritesh,
you can use the "Mouse Down?" event to check which mouse key is pressed and change it to 2 if it was 1. This activates the menu also on left click.
Mike
(2,910 Views)
Hey Guys,
Thanks alot.
It worked. :smileyhappy:
Ritesh
(2,896 Views)
