active x error
hi everybody!!!
well, i am working with a program, READ_XCLPRUEBA,   i read information from a excel sheet,
well if i run the program works properly, but the problem come when i exectate it twice, the second time give me an error that i can't solve, so i must run and close the programm every moment i want to do something with this...why is this??  can someone help me please??
TAKE MY VI,S TO WORK IF YOU WANT!!
THANKS!
Message 1 of 19
(8,822 Views)
What is the error description, error code? You should have mentioned about the error.
Sometimes error can not be replicated..sometimes they can be PC specific or software version specific.
I hope you got my point.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 19
(8,819 Views)
Have you closed references that you no longer need?  this is a common problem when using ActiveX and Excel
Can you send your vi as a *.vi file rather than a *.zip file (my organisation forbids the download of *.zip but allows *.vi for some reason)
Message 3 of 19
(8,817 Views)
Sorry Gak!!
that is the error,
Error -2146827284 occurred at Unknown System Error in OPENWorksheetTDMS.vi->READ_XCLPRUEBA1.vi
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (-2146827284) or for its hexadecimal representation (0x800A03EC).
and i put again the zip because i have forgotten to attach one subvi!
thanks!
Message 4 of 19
(8,814 Views)
ok Kenneth Naylor here you have in vi format,
the readxclprueba is the principal vi, others are subvi..
Message 5 of 19
(8,811 Views)
Kenneth Naylor, opnly i can send it 3 by 3 so..waiti will say you when i finished
Message 6 of 19
(8,809 Views)
 finish with this this is the last one!!
thats all!!
thanksss!
Message 7 of 19
(8,805 Views)
And the block diagram passwords!?
Message 8 of 19
(8,802 Views)
Hi Alan,
This is the same error which you had posted last time. Here.
Please check.
Gaurav k
CLD Certified !!!!!
Message 9 of 19
(8,797 Views)
but i make changes on it and doesn't improve... and now is the same error bt appears in other location doesn't it?
Message 10 of 19
(8,794 Views)
