active x to control Array 3700 DC electronic load
I want to control Array 3700 DC electronic load using LabVIEW.
I have software to this instrument and it works correct. It is connected by USB.
I have installed OCX library.
in attached file are: ocx library, instruction how to install it and file with installed active x
Has somebody idea how to do it?
I tried something like this but it doesn't work.
(2,980 Views)
on picture is empty place near 'Port'. I raid numbers 1-8 buy it doesn't work. It is probably information about 'COM' where my instrument is connected.
(2,978 Views)
Sorry ArturM, I'm a little unclear as to what your question is.
I recommend reading section two, found at the bottom of this page:
http://zone.ni.com/devzone/cda/tut/p/id/3831
It has some explanation on 'COM' which may help.
Rhys
(2,930 Views)
