shared variable (FIFO)
Hi everybody
I'm using the RT module and I created a FIFO which is shared between the host and RT. I received from RT points from a graph. A point appeared in the RT module every 4khz. My processor is faster 8.5 Ghz. I placed a Wait of 0.25 ms in order to be sure that the fifo is not empty.. However the error code -2220 appears and another error code -1950679023 which means that the connection to the server disconnected... I don't understand why..
If somebody can help me it would be great
Thanks a lot
(2,762 Views)
Bonjour,
Ce forum traite d'une erreur similaire et vous pourrez peut être y trouver la réponse à votre problème.
Cordialement,
Thomas B. | CLAD
National Instruments France
(2,734 Views)
