activex events not seen in Labview
I have PC application which has a COM server interface included.
I am able to connect to this successfully with labview for everything apart from events. When I try and connect to events it always comes back with error 95, event unknown. I have also tried the "list events descriptions" and that comes back empty.
The COM server works fine when used with VB and C++ applications so I am guessing Labview is the problem.
I am using a Automation Refnum control to access the COM server and this is working fine.
Any suggestions why I can not see any events in Labview?
(I am running Labview 6.0.2)
(2,460 Views)
No problem with events with LabVIEW 7.1 ...
(2,450 Views)
Thanks for the reply. I just tried an evaluation copy of Labview 7.0 and managed to get it working with the new feature "Register Event Callback".
I would still like to use Labview 6.0.2 if possible as I don't believe I will use most of the new features in Labview 7.0 and 7.1. Also we have alot of version 6 licenses that will cost alot of money to upgrade!
Any suggestions how I can get 6.0 working with events?
Matthew
(2,431 Views)
