add an output to a sub-VI
Hello everybody,
I want to add an output to a sub VI but when I right-click on the icon in the upper right-hand corner, I don't find "Show connector" and have no possibilities to select a different pattern.
The VI properties shows "VI unlocked".
François
(3,068 Views)
Accepted by GxABT_Mechanical
Did you right-click on front panel? If you click on block diagram you won't see "Show connector" option.
BR,
Jick
(3,058 Views)
