add file extention into file type combobox of open dialog box
hi.
how can i add my favorite file extention (for example .kmt) to the file type combo box of 'Open' and 'Save As' dialog boxes. the default is All Files and i want to add one more extention.
thanks.
ali mootab.
(2,736 Views)
The File Dialog VIs have a pattern input that is defaulted to all Files.  You can simply wire in the pattern you want, multiple patterns are semicolon delimited.
(2,733 Views)
To be complete the pattern you need is
                 *.kmt
not just kmt
greetings from the Netherlands
(2,723 Views)
