add five minutes to time stamp
Dear all LabView Superusers,
I would like to know how to add five minutes to the time stamp, is it possible?. Prior thanks for the help.
Best Regards,
Lee Joon
Message 1 of 8
(10,434 Views)
Do you mean that you want to shift/ increment a signal/waveform's start time ( t0) by 5 minutes??
Message 2 of 8
(10,431 Views)
Hi Lee,
take a timestamp, wire it to an add function. Create a numeric constant, set value to 300 (=5*60s), wire it also to the add functin. The result will be a timestamp with added 5minsSmiley Wink
Message 3 of 8
(10,429 Views)
To expand Gerd's idea:
Ton
Message Edited by TonP on 03-17-2008 11:09 AM
My LabVIEW Ideas
Message 4 of 8
(10,421 Views)
Dear all,
Thanks for the help :-). It works very well.
Lee Joon
Message 5 of 8
(10,388 Views)
Dear all,
I have found another solution for this. See attached :-), but the solution from TonP is much more simple. Thanks.
Best Regards,
Lee Joon Teow
Message 6 of 8
(10,364 Views)
Hi LJ,
your solution works - but belongs to the Rube Goldberg section Smiley Wink
It's just unneccessary to convert the timestamp to a date/time record, do the adding and convert back to timestamp when you also can add to the timestamp directly!
Message 7 of 8
(10,347 Views)
Just for fun, you can also display the units for the constant, and set the unit to be "min".
___________________
Try to take over the world!
Message 8 of 8
(10,320 Views)
