add icon/decal to array index button
Hi all ,
I know that it is possible to customize controls, e.g. you can add an icon (decals) to a blank button:
how to add a icon / decal to the array index button . in ( type def  .ctl file )
(2,992 Views)
Hi willcan,
what is an "array index button"?
Array controls are built from an array container, the array element and a numeric index control…
(2,990 Views)
Hi Gerdw,
Array index display button i am asking . !!
for sample i attached a picture here using enum
Adding the decal / icon on the array index display button ??
(2,953 Views)
Hi willcan,
You talk about those increment/decrement buttons?
You may try to replace their image in the control editor - it's called "customization"…
I tried this and failed to do so - I'm not so experienced in (advanced) control customization. As a workaround you can hide the inc/dec buttons and place your own buttons next to the array control.
(2,950 Views)
Hi gerdw ,
Yes on Increment / decrement buttons only .
placing own buttons next to array control ?? cant get you >?
(2,937 Views)
I believe that the first video from this whitepage will answer your question.
http://www.ni.com/tutorial/14131/en/
(2,921 Views)
