add marker
Hello..
Let me define my final goal: building a modern spectrum analyzer by the SR-760 model.
The Problem:
i need to add a MARKER to the Spectrum graph output.
MARKER mean that in the real spectrum analyzer there is a "turning scroll button" that you rotate it and on the screen you see a cursor running on the Spectrum lines
( all the cursors and markers in this forum relate to the graph itself, regarding the lines that display on the graph...)
my question: how do i add a cursor to the graph that change accordinly to the signal displayed on the graph??
basicly i would love to get any information about this subject - for instance, later on i need to add a "Next Peak" button - that related to the signal as well..
hope i was clear abot the question.
another example - Let say i have a 3 sin wave in different frequencies.  fft(signal) -> result 3 main harmonic,
display on the graph - three impulse.
marker cruise on the signal lines on the graph , and on the side display each time what is the x value and y value.
later adding next peak button and now each time you press it the cursor jumps between the impulses..
(4,340 Views)
Seems like you want a cursor that is locked to a plot.
Here's a quick example (LV 8.5.1) where you can pick the plot # and cursor X with controls and it will give you the corresponding Y. Modify as needed.
(4,325 Views)
YES - this is exactly what i need.
but im trying to imply your code on my VI, i think something missing,
i didnt add the TIMEOUT thing - im not really sure how to use it, the steps iv done:
1.right click on the grap->creat->Property Node->Cursor->Cursor Position->Cursor X ( did the same to Y)
2. add Cursor to graph through the "Front Panel"
3. made cursor X as Write
4.made cursor Y as read ( cause i just want to display the Info from the graph)
result: the program runs, but im not controlling the cursor and im not see any value of cursor y
my guess im not using reference or something like that..
my question is:
1.how do i connect the cursor from the property node to the cursor iv added in the front pane?
 2.is it posible to create a "Maximum" and "minimum" buttons, so the cursor will jump to that area in the graph...
thank for the help altenbach
(4,313 Views)
It would be much easier to tell what's wrong if you could attach your VI. 😉
(4,306 Views)
Ok sure,  the are is in the top left
the graph caled "simulate Signal"
(4,300 Views)
You created "free" cursors. You need to create "single-plot" cursors.
(4,291 Views)
