05-09-2009 08:07 PM
hi,
my question is rather simple,may be because i couldnt find the option. actually i want to resize the window size to my front panel size, so that the rest of the unused area could not be showed up when i run VI, but i couldnt find any option how to do that, i tried with VI properties in FILE menu but it seems not working, plz guide me how could i do this. thanks alot
Regards
05-09-2009 08:18 PM
What I do is set the MINIMUM WINDOW SIZE (under the WINDOW SIZE portion of VI PROPERTIES) to the size I want the window to be at runtime.
Then, if it gets messed up during development, I just shrink it to minimum, and save the VI again.
05-09-2009 08:18 PM
