how to scale window size to VI panel?
hi,
my question is rather simple,may be because i couldnt find the option. actually i want to resize the window size to my front panel size, so that the rest of the unused area could not be showed up when i run VI, but i couldnt find any option how to do that, i tried with VI properties in FILE menu but it seems not working, plz guide me how could i do this. thanks alot
Regards
(3,045 Views)
What I do is set the MINIMUM WINDOW SIZE (under the WINDOW SIZE portion of VI PROPERTIES) to the size I want the window to be at runtime.
Then, if it gets messed up during development, I just shrink it to minimum, and save the VI again.
Steve Bird
Culverson.com
LinkedIn
(3,041 Views)
all you have to do is fit the front panel to the size you want it and than save it, the next time you open the VI it should be in the size you put it in. (this will also be the same for runtime.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,040 Views)
