add register card to register element
Hi all,
I want to add a specific number of register cards to a register element. This number should be given by the user.
How can I do this?
Rusja
(4,201 Views)
Is this a LabVIEW problem?
(Sorry, I am not familiar with your terminologies.)
(4,198 Views)
yes it is a labview problem.
(4,196 Views)
I am afraid we need a bit more detail.
What is a "register card"? (even google does not really know :o).
Maybe you can attach a simple LabVIEW code example that shows the basics problem. Thanks! 🙂
(4,184 Views)
I think "register card" is a direct translation from the German "Registerkarte", which translates to "tab control" in software terminology.
Jochen
(4,169 Views)
Sorry, you are right. It is a tab control in english, It was a bad translation.
Normally you can add a new page to the tab control directly on the front panel.
But I want that the user is able to determine the number of pages of the tab control.
I tried to use property nodes but I failed.
Thanks for your help
rusja
(4,164 Views)
Accepted by rusja
Maybe this will help. Good luck! 🙂
(4,153 Views)
