Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
add shared variable library to project
DavidT
Active Participant
09-08-2006
12:50 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi All,
How do i add an existing shared variable library to a new project?
Kudos
Message
1
of 4
(3,412 Views)
Reply
Re: add shared variable library to project
ChrisRP
Member
09-08-2006
08:18 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Right-click on My Computer (or an RT Target) in the Project and choose "Add File..." from the pop-up menu.
0
Kudos
Message
2
of 4
(3,403 Views)
Reply
DavidT
Active Participant
Author
09-10-2006
06:10 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks, i was using the 'Add Folder' option without success.
0
Kudos
Message
3
of 4
(3,377 Views)
Reply
Rudi_N
Active Participant
09-11-2006
10:08 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
David:
Were you then able to add a shared variable library to your project ?
Let me know if I can help in any way.
Rudi N.
Applications Engineer
0
Kudos
Message
4
of 4
(3,361 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
