add strings
I want to create one large string from an array of strings. Each string in the array is 16 characters and the array has 30 elements, so I want to create one string that is 480 characters long. Attached is a VI showing an approach that I think will work but I would like to know if there is a better approach.
I need the long string because I have to calculate a CRC-32 value.
Thank you,
Chuck
(6,311 Views)
Accepted by chuck72352
Index array is stretchable for more outputs, and the indices increment themselves automatically starting at 0 by default if nothing is wired to them.
 Concatenate strings will take in an array of strings as well as individual strings.
Message Edited by Ravens Fan on 03-13-2010 01:00 AM
(6,306 Views)
In the "what you should be doing" approach, what is the function that you're using?
Chuck
(6,274 Views)
I just found it, "concatonate string"....thank you!
(6,271 Views)
Hi mohansagar,
why do you:
- attach a proprietary file format instead of plain pics?
- why do you link pictures residing on your local PC?
- why do you suggest to convert an array to a cluster to unbundle elements to build a string? A much easier/better solution was already suggested before…
Who is kudoing such suggestions?
(6,150 Views)
The OP kudoed the response.
Richard
(6,137 Views)
