add vb code to labview
I've created a labview application that I'd like to add some VB code to. Is it possible to run vb code from labview or do I need to convert the vb to labview?
I've attached the vb code.
(4,827 Views)
You need to create a dll or .NET assembly from the VB code (depending on the version of VB being used). Converting to LabVIEW would of course, be another option.
(4,818 Views)
That particular code is VB.NET so you'd need to create a .NET assembly, and use the .NET functions in LabVIEW to call the assembly. However, some of the code may give you issues, such as the stuff dealing with Forms.
(4,799 Views)
do you have any examples that you can show me, how to use the .NET assembly to run this vb code?
(4,783 Views)
Well, you first have to compile the code into a .NET assembly. Can't do this with LabVIEW. Smiley Wink You'll need to get yourself VB.NET. You can get the free Express editions from Microsoft. Then, as far as using the .NET assembly in LabVIEW, there are examples that ship with LabVIEW.
I am assuming you know how this particular assembly is supposed to be used. If not, then you first need to figure that out, but for this you'd need to go to where you got that source code.
(4,781 Views)
