adding a start button to my visa vi so I can build an executable
If you do not create an installer and have not previously installed visa and serial on the target computer then then they are not installed.  If you are building this for internal use you can install them from the ni website.  Search for ni visa and ni serial, CONFIRM THEY ARE THE RIGHT VERSION FOR YOUR .EXE. Otherwise you can create an installer from your project. Ive added a link to an NI tutorial for this. Section 5 covers installers.
Good luck
http://www.ni.com/tutorial/3303/en/#toc5
-Matt
Message 11 of 14
(1,143 Views)
Hi Matt,
I installed labview runtime and visa runtime on the target and still the exe would not detect com ports. I couldn't see a serial runtime but I did install ni serial in the target computer.
I tried to build an installer and for some reason it couldn't find the visa path and the installer build failed. The visa is located where the other labview files so I cannot understand why I am getting this error.
I feel at this stage it mite be easier for the end user to install an Eval version of labview and visa and then run my vi.
Message 12 of 14
(1,140 Views)
If it is just for internal use, say a few people, they can install these on the target computer from ni.com.  You most likely need to install ni serial though.
Provided is a link to ni serial 15. I dont know your development environment, but you can read the compatibilties on this site as well.
http://www.ni.com/download/ni-serial-15.0/5573/en/
-Matt
Message 13 of 14
(1,132 Views)
Do you still have the install disks you used to install LabVIEW and the drivers?  The app builder probably just needs to "cache" the VISA installer.  It can do that if you have the original disks still.
Message 14 of 14
(1,127 Views)
