adding beep sound to button
hi everybody,i would like to make a vi where by when a user clicks on a wrong button,a beep sound is made like many  windows applications do...does anyone know how to do this ?thank you in advance
(4,665 Views)
Accepted by topic author alpony01
Use an Event Structure to see when the user presses the button.  Look in the Graphics &  Sound palette.  There is a Beep.vi in there that you can use.
(4,662 Views)
How are you defining 'wrong button'? You can use property nodes to enable/disable/show/hide the buttons so a user cannot make the wrong choice.
(4,657 Views)
well in the end both i can use both your suggestions since they both solve my problem..thank you very much!
(4,610 Views)
