complex spectrum indicator
HI,
How do I display a complex spectrum as an indicator graph, I can only seem to display it in cluster property format or is this the only possible way to display the data?
(3,115 Views)
Hi nashm,
can you provide an example of how it should look like?
You could separate amplitude and phase from your complex spectrum into single plots…
(3,110 Views)
