adding multiple separators in combo box
i want to add multiple separtors in my combo box items but i can add - Value in the items list only once so i get only one separator, how can i add multiple separators in combo box items
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
Message 1 of 9
(7,868 Views)
A combo box cannot have duplicate values, so you need to uncheck the Value match labels checkbox and give the duplicate seperators other values (e.g. sep1, sep2, sep3).
___________________
Try to take over the world!
Message 2 of 9
(7,856 Views)
I tried that already, but it doesnt work
it does not allow duplicate values, as well as duplicate item names. also only - creates a separator and not -- or --- etc.
Tushar Jambhekar
Message 3 of 9
(7,847 Views)
The built-in editor (accessed by right-clicking on the control and selecting "Edit Items...") won't let you do it, so you have to set the items programmatically. For a System Combobox (which I'm assuming is what you're using) you could just do this:
Message Edited by smercurio_fc on 07-05-2007 09:11 AM
Message 4 of 9
(7,840 Views)
Works fine here:
Actually, I would argue that this is a bug in the editor, which should ingnore duplicate hypens if they have a special value.
___________________
Message 5 of 9
(7,823 Views)
Here's what the "Edit Items..." looks like for the System->Combobox on my system (LabVIEW 8.2):
Message Edited by smercurio_fc on 07-05-2007 10:32 AM
Message 6 of 9
(7,818 Views)
Thanks smercurio_fc
as per your saying i could add up multiple separators programatically.
by the way tst which version of labview you are using. i am using 8.2.1
Tushar Jambhekar
Message 7 of 9
(7,798 Views)
The version it worked in was 7.0, but I'm seeing the same thing you are seeing in the current beta.
I added this thread to the bug list.
___________________
Message 8 of 9
(7,790 Views)
FYI This is still the case in 8.5. It has been reported with CAR ID 4CG73J69.
Stephanie
Message 9 of 9
(7,655 Views)
