detect usb drive on crio
Hi all,
I'm using a crio-9014 to build a small data logger which saves its data onto an external USB hard drive. For usability and data safety reasons, I would like to add an indication wheter the USB drive was recognized correctly or not (e.g. fast flashing of the user LED at startup when there is no drive detected).
My problem is: How do I detect if there is a proper mounted, accessible USB drive at the port? If I just perform a write to, say, "u:\test.txt" and there is no USB drive, I don't get an error from the write function - it just writes the file to "c:\u\test.txt". So just trying to write something to the USB drive and looking for an error doesn't seem to work.
Does anybody know of a way of checking if the u:\ drive is correctly mounted on a VxWorks controller?
Stefan
(7,762 Views)
You should get the contents of the root:
The 'folders' are the volumes currently available on the computer.
Ton
Message Edited by TonP on 08-17-2007 12:20 PM
My LabVIEW Ideas
(7,755 Views)
Thanks Ton,
this will work - but only if you don't have a folder called "u" on your crio (which is created if you try to access the u:\ drive without a USB drive attached).
So my problem is - if somebody disconnects the drive while the logger is running, it will create this folder and then not be able to detect a missing drive anymore at the next startup.
Stefan
(7,738 Views)
I just found out one more thing:
What Ton proposes works on a Windows Machine - on the VxWorks cRIO controller listing the folders of the Root will list the folders of the Root of the flash drive - which is drive c:\!
So this will not work on the cRIO controller. Any other ideas?
Stefan
Message Edited by StGl on 08-17-2007 01:45 PM
(7,740 Views)
OK - I screamed out too fast - it's really as easy as this: (see attachment)
Sorry
Stefan
(7,733 Views)
Stefan
Could you show the code that performs this error?
Ton
My LabVIEW Ideas
(7,728 Views)
Hi Ton,
I used exactly the code you posted - on a Windows machine it outputs an array of drive letters (C,D,E etc.), but on the VxWorks controller, it outputs the root of the flash disk (ni-rt, temp etc.). I guess that's due to the fact that in VxWorks there is no such filesystem root in front of all drives as in Windows ("My Computer"...).
However, trying to get the drive info for the U:\ drive fails if you don't have an U:\ drive - also on VxWorks; so that's a good solution for my initial problem.
Stefan
Message Edited by StGl on 08-17-2007 04:02 PM
(7,721 Views)
