09-23-2010 11:17 AM
i generated a signal y=a*sin(w*t) on time domian ( here time is varying)
now i want to add noise to y i.e y1=y+ % of amplitude of noise * y
to solve this i did like this but i dont know whether it is correct or not
can give me a solution or hint.......
09-25-2010 12:12 AM
hi sir plz tell me whether iam going in correct way or not.......
09-25-2010 01:01 AM
09-25-2010 02:00 AM
thanq for ur reply sir
sir by mistake i wrote 10 its ok
but after filtering iam getting exact value of amplitude but not phase
how can i get both amplitude and phase exactly after filtering (amp n phase should match to input values after filtering)
plz reply me.......
09-25-2010 02:04 PM
Filtering causes a phase shift. Maybe this old discussion will give you some ideas.
09-26-2010 09:57 AM
Why do you want zero phase. Unless this is specified in your assignment. I would not think about it. As it is inherent part of IIR filtering. But I am surprised that you teacher allow the extensive use of Express VIs.
09-26-2010 12:10 PM
sir my problem is explaining here..........
let i havegenerated a sinsignal having amplitude, frequency and phase
after filetring iam getting correct amplitude
but phase is changing. i want exact phase as we given...........
how can i achieve this sir plz reoly me..........
if u want i can post my vi.....
09-26-2010 01:00 PM
no sir my teacher didn't allow me to use this
just i find that this is easiest way thats way i am using express VIs
09-27-2010 07:46 AM
Whenever a signal is passed through a filter, there is some phase delay introduced by the filter. For a better picture, you can analyze the phase response of the filter.
09-27-2010 10:52 AM
k thanq sir
sir small doubt
To simulate a sine wave just i have used simulate express vi n added noise because option is there (is this correct procedure to simulate a sin)
n if i use control n simulation loop how can i add noise to sin signal function
