adding noise to y = a sin(w*t)
i generated a signal y=a*sin(w*t) on time domian ( here time is varying)
now i want to add noise to y i.e y1=y+ % of amplitude of noise * y
to solve this i did like this but i dont know whether it is correct or not
can give me a solution or hint.......
Message 1 of 13
(5,009 Views)
hi sir plz tell me whether iam going in correct way or not.......
Message 2 of 13
(4,932 Views)
  • Why are you dividing the noise by 10? That does not give you percentage. It should probably be a fraction of the amplitude.
  • Gaussian white noise is probably more realistic than uniform white noise.
Message 3 of 13
(4,926 Views)
thanq for ur reply sir
sir by mistake i wrote 10 its ok
but after filtering iam getting exact value of amplitude but not phase
how can i get both amplitude and phase exactly after filtering (amp n phase should match to input values after filtering)
plz reply me.......
Message 4 of 13
(4,924 Views)
Filtering causes a phase shift. Maybe this old discussion will give you some ideas.
Message 5 of 13
(4,874 Views)
Why do you want zero phase. Unless this is specified in your assignment. I would not think about it. As it is inherent part of IIR filtering. But I am surprised that you teacher allow the extensive use of Express VIs.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 6 of 13
(4,843 Views)
sir my problem is explaining here..........
let i havegenerated a sinsignal having amplitude, frequency and phase
after filetring iam getting correct amplitude
but phase is changing. i want exact phase as we given...........
how can i achieve this sir plz reoly me..........
if u want i can post my vi.....
Message 7 of 13
(4,834 Views)
no sir my teacher didn't allow me to use this
just i find that this is easiest way thats way i am using express VIs
Message 8 of 13
(4,822 Views)
Whenever a signal is passed through a filter, there is some phase delay introduced by the filter. For a better picture, you can analyze the phase response of the filter.
Message 9 of 13
(4,772 Views)
k thanq sir
sir small doubt
To simulate a sine wave just i have used simulate express vi n added noise because option is there (is this correct procedure to simulate a sin)
n if i use control n simulation loop how can i add noise to sin signal function
Message 10 of 13
(4,757 Views)
