Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
adding present samples with past samples
J2LV
Member
05-13-2007
12:41 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
hey !
my problem is that i want to take the average of 250 samples.
now how can i add present samples with past one so that i can divide it by 250 in the end .
thnks in advance.
0
Kudos
Message
1
of 3
(3,092 Views)
Reply
Re: adding present samples with past samples
NyRe
Member
05-13-2007
12:57 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If you have a numerical array and want to take the sum of all its elements use "Add Array Elements" function located in the numerical palette.
If you're able to control the array during it's creation, use a Shift Register for the sum.
0
Kudos
Message
2
of 3
(3,088 Views)
Reply
mikeporter
Proven Zealot
05-13-2007
03:16 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Also check this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=246094
It covers what you want to do, giving several different approaches...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
"... after all, He's not a
tame
lion..."
0
Kudos
Message
3
of 3
(3,079 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
