adding trigger to oscilloscope
Trying to add trigger to oscilloscope. I want to use the trigger as subvi. But have no idea how to do that. Here I am trying to search the data to find the index at which the trigger condition occurs, and then using that index to cut off the pre trigger portion of data and keep next samples to display.
Could someone please help me.
Message 1 of 11
(8,081 Views)
Hi anny,
Could you send me your VIs for version 2015 ?
Kudos are welcome Smiley Happy
Message 2 of 11
(8,078 Views)
Thanks for your reply. please find the VI for version 2015.
Message 3 of 11
(8,072 Views)
Accepted by anny321dum
Ok, I see.
this is the diagram of your sub vi
configure your icon and connector of this sub vi and use it in your main vi.
if you have any question, let me know.
Message 4 of 11
(8,050 Views)
Hi anny,
There is nothing related to a scope in your VIs…
Do you know how to use VIs as subVIs? If not: take the beginner courses offered by NI here.
You need to connect controls/indicators of your subVI with its VI connector.
Then place the subVI in the main VI and wire any in/out connection you need with your subVI.
You need to edit your subVI as well. Currently it isn't executable…
Message 5 of 11
(8,048 Views)
That works thanks a billion. Can you also tell me how it works if I use basic level trigger vi. I tried implementing your idea but it did not work.
Thanks again. You can check my triggering VI.
Message 6 of 11
(8,019 Views)
Hey GerdW,
Thank you for your reply. I know how to create a sub VI but I was having a problem on applying a trigger using basic level trigger vi.
Message 7 of 11
(8,018 Views)
Hi anny,
What about the LabVIEW help for this function?
It also links to an example VI!
Message 8 of 11
(8,013 Views)
I am having hard time in finding the example. Would really appreciate if you can point at right direction.
Thanks!
Message 9 of 11
(8,004 Views)
tap "Ctrl+H" to open control window on vi level trigger detection
Click here,
and,
Message 10 of 11
(7,998 Views)
