addressing old (non NI) DAQ cards
I'm trying to use an old Metrabyte DDA06 analog/digital I/O board in Labview.
The board has hex base address 300. I want to write to a 12 bit port with
offset
0 and 1, which in BASIC would be as simple as:
OUT &H300, DL%
OUT &H301, DH%
I cannot, however, figure out how to connect the base addres with a resource
name that VISA Open recognizes. None of the cryptic resource names that
VISA Find Resource identifies (ASRL1::INSTR,ASRL2::INSTR,ASRL10:) seem
to correspond to the DDA06 board. I get the following error message when
I
try to write the high and low byte to offset 0 and 1:
-1073807257 VI_ERROR_NSUP_OPER The given session or object
ref
erence does not support
this operation.
All information I have found so far always refers to adresses relative to
the
device base adress. And by the way: no, I do not have a Windows driver
enabling me to making Windows aware of the device by "Add new hardware".
Thank you in advance for de-mystifying LabView for me,
Dag Kristian
(2,751 Views)
One thing you might try is to look at the KnowledgeBase article on accessing
the parallel port from NT
(http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/c80752c53
094c296862565f3007ac765?OpenDocument). The llb and zip files at the bottom
of this article can be used to talk directly to the parallel port by using
its address (like 0x278). I have used the In Port.vi and Out Port.vi to
directly talk to hardware. Perhaps you could adapt the code to write to and
read from your DAQ card.
Hope this helps.
Jim
Dag Kristian Dysthe wrote in message
news:392d9492@newsgroups.ni.com...
Labview.
port with
> offset
> OUT &H300, DL%
> OUT &H301, DH%
resource
> I
> reference does not support
> this operation.
> the
> Dag Kristian
(2,751 Views)
