ini file
Hi.
I would like to how if it´s possible to pre-initialize the serial port at
19200 baud rate when the LABVIEW programm loading.NOT WHEN THE PROGRAMM
RUNNING.
(3,064 Views)
On Wed, 24 May 2000 14:36:21 +0200, "Jior" wrote:
>Hi.
>RUNNING.
What about initiializing it and have a timer in the loop to make it
wait a few second before the program runs.
Or set it up in Windows ?
Steve Drake
(3,064 Views)
Hi Jior
You could try loading parts of the code as you need them, by using VIserver.
Ex.
The program just loads the serial init functions first and runs. Which in turn, using VIserver, loads the rest of the program at
hte same time it is initialising the serial port.
Tim
Jior wrote:
> Hi.
> RUNNING.
(3,064 Views)
