advantech pci-1751 card
Helloo,
I am using Labview 7.0,  PCI-1751 advantech card, and ADAM3968 68-pin SCSI cable wiring.
Here I wanted to configure the port 0 of pci-1751 card as a output port and wanted write some digital data on to that. For that i am using "
port config.vi" to configure the port 0 as a output port and "port write.vi"  to write my digital data. Here i found no error when i run my my.vi file. But when i saw output voltage at output of ADAM 3968, i found my digital data is not coming. So how to configure the card and how to send my digital data on to that port. Please help me in this to solve my problem.
thanks & reagrds,
Ravi Kumar
(3,604 Views)
I hope you are not trying to use the traditional daq functions called DIO Port Write and DIO Port Read. That would be silly since those are only for NI boards.
(3,587 Views)
Actually I am very new to this labview. Only 2days experince with labview.
I solved my problem what i stated before. Yes i am using DIO write and DIO read but then also it came wrong because i given wrong device number. Which should be according to the serial number in advantech device manager. Thank You very much for your reply.
Thanks & Regards,
Ravi Kumar.
(3,573 Views)
