afficher sur graphe xy
bonjour ,
je veux faire un programme en labview mais j'ai un problème en affichant sur le graphe xy(je suis debutant).
je veux afficher les valeur d'une variable en fonction des valeur d'une autre ,mais le graphe ne m'affiche pas la courbe ,il affiche seulement les grilles.
quelqu'un peut m'aider.
voici un simple exemple (english or french no problem)
Message 1 of 8
(3,627 Views)
Hey Salah
I dont know what you are looking for. But as far as i understood you are tryin to plot a grpah based on different values in A, B and t.
See attachment if that is what you want
Nghtcwrlr
Message 2 of 8
(3,619 Views)
thank you Nghtcrwlr
yes that is my purpose but i want to use the while loop instead of for , and i tried to use while loop but nothing appears on xy graph
do you have any solution?
Message 3 of 8
(3,614 Views)
Accepted by topic author SALAH.H.M
You can also use a While Loop . You can use a wave chart then... see this :
Nghtcwrlr
Message 4 of 8
(3,606 Views)
where and how can i find the waveform chart?
Message 5 of 8
(3,596 Views)
look i aim to plot the result of the (formule) function of the iterations
Message 6 of 8
(3,592 Views)
Right click on the front panel... there you will see graph indicatiors. Inside that seöect "Chart"
In general if you want to search / find something , type it in the search box
See below:
Nghtcwrlr
Message 7 of 8
(3,581 Views)
hello
thanks i found the solution it contained in the attached piece
Message 8 of 8
(3,578 Views)
