agilent 548xx driver for labview 8.0
Hi, I am using the agilent 548xx dirver for labview 8.0 and a small problem is annoying me.
The Initialize VI needs resource name input, but I couldn't wire a VISA resource name control or any other I/O resource control to it.
Does anyone can help me out? Thanks a lot!
(2,616 Views)
You are using the IVI driver and not the LabVIEW one. The IVI driver requires an IVI Logical Name and not a VISA Resource Name. Just right click on the input and select 'Create Control' or 'Create Constant'. The IVI Logical Name control is on the I/O palette. If you drop the generic control onto the front panel, you need to select the correct class before wiring it.
(2,611 Views)
