ai group config
we have an application that needs to be modified to use a 4 module scxi 1000 chassis from a 10 module amux chassis and i believe my trouble comes from changing the ai group config.vi to match the scxi chassis. i would appreciate some help with this.
(2,556 Views)
Greetings,
You are probably experiencing problems with the channel scan list input to AI Group Config.vi. When using an SCXI system, it is important to have a correct understanding of the SCXI Channel String. Below, I have included a link to a KnowledgeBase with detailed information concerning the use of SCXI channel strings:
Valid SCXI Channel String Arrays under LabVIEW
Good luck with your application.
Spencer S.
(2,556 Views)
