Greetings,
You are probably experiencing problems with the
channel scan list input to AI Group Config.vi. When using an SCXI system, it is important to have a correct understanding of the
SCXI Channel String. Below, I have included a link to a KnowledgeBase with detailed information concerning the use of SCXI channel strings:
Valid SCXI Channel String Arrays under LabVIEWGood luck with your application.
Spencer S.
