an event controlled single string transmission
I have problems with an event controlled single string transmission.
Inspiration: Basic serial write and read example in Labview 7.1.
My problem is that the string is retransmitted several times.
Best Regards
kas
(2,478 Views)
Is this a continuation of this post? You should really have replied to that instead of starting a new thread. Starting a new thread is just confusing to everyone. How did you modify the example? Better yet, instead of explaining, why don't you just post the example?
Message Edited by Dennis Knutson on 09-27-2006 07:49 AM
(2,474 Views)
