analog pause
Good morning ,
I am working on the NI USB 6361 card and I would like to try the analog pause, and it works well but I have a problem when displaying the signals; in the image I put a square signal between -3V and 3V on the GBF but the display is not good at all
what is this due to?
thanks in advance
(1,389 Views)
@ameletudiante99 wrote:
Good morning ,
thanks in advance
What do you expect to see?
(1,379 Views)
a square signal between -3V and 3V,
(1,353 Views)
Accepted by ameletudiante99
Well, I understand it this way: You pause the data acquisition when the signal falls below 0,5, so there are no samples between 0,5 and -3.
You see the samples with a value of 3,1 and from time to time a value between 3 and 0,5 (falling or raising edge).
In the graph your data is connected from point to point, which produce these triangle peaks.
If you want to see a square signal you should not pause data acquisition.
Disclaimer: Since you only posted a picture of a front panel I can't look at the real configuration for the data acquisition.
(1,342 Views)
yes it's true when I don't use a trigger pause I have the signal correctly;
What I understood about pause trigger is to suspend the acquisition if I have a voltage lower than 0.5V and to resume if it ever increases
for the tests I used an example that I found in the labview library,
as a source I used the ai0 analog input where I also connected my signal
(1,324 Views)
