analogy output a 5000 Hz sine wave from DAQ 6015
Dear Friends,
I am back again. Today I try to use the DAQ 6015 to generate an analogy output sine wave of 5000 Hz, it shows me underflow warning. I think it is because of the limit of the on board buffer size. However, I would like to ask for some advice from your experienced expert if there is any way I can make it.
Many Thank
dan
(2,666 Views)
Hi Dan
Just a few questions before I can help you. Are you using LabVIEW, if so which version. Are you using NI-DAQmx driver, again if so which version. When you receive the underflow warning do you also encounter an error code and description of the warning? Would it be possible to post the message and code in your next post.
You can setup buffer size and sampling rate via LabVIEW. Using the DAQmx API makes this very easy using the DAQmx Timing.vi
Kindest Regards
Yatin | NIUK & Ireland
(2,648 Views)
