analysing waveform for digital values stored in a file
i have certain digitals values obtained in a file in .txt format.
i have to obtain a waveform by giving the input as these digital values in that file.
I have programmed for array input manually.
But the waveform analysis should be made such that it do analyze automatically by taking the values stored in the file.
The values are stored as like follows-
0.00159
0.01432
0.01654
0.15432
etc
Give me a module to do this task.
(2,705 Views)
Look at Read from Spreadsheet File in the File I/O palette.
(2,701 Views)
Use the Read from Spreadsheet file and then just connect it to a waveform chart. This will do what you need. Post back.
(2,694 Views)
