anoying LabVIEW Logo
is there a way to remove that anoying LabVIEW Logo in the lower right corner of every VI?
(2,642 Views)
Are you using the evaluation version?
If so, the answer is yes - Buy the full version.
If you are using the full version and you have it, maybe it's something that stayed from the eval version. You will probably have to uninstall and reinstall (or at least repair), because I doubt NI will tell you how to remove it.
___________________
Try to take over the world!
(2,634 Views)
