want a constant time axis in waveform chart
hello,
my time axis in waveform chart is changing .how can i keep it constant say 1-100 .the whole point of this is to make waveform chart luk like a CRO.please need help.
thanks in advace
naveen.rabelli
(2,466 Views)
I don't think what you're asking for is possible, due to the nature of the chart - it accepts Y values and inserts the X value automatically. Offhand, I can think of 3 solutions -
The bad one - constantly change the offset by moving it backwords. You will probably have flickering.
The workaround one - Paste a text box over the first number saying 1 and another over the second number saying 100.
The probably most correct one - Use a XY graph. Just have a 1D array of 100 elements and append it to a second 1D array with 1..100. Wire the 2D array into the graph terminal.
___________________
Try to take over the world!
(2,453 Views)
