anybody know about...?
this is a question about table... it is hard to explain...
so, i had attach a VI to here... hope can get answer very soon 🙂
Message 1 of 19
(4,632 Views)
Solution is attached
CC
Chilly Charly    (aka CC)
Message 2 of 19
(4,627 Views)
Hi... chiily....
thanks for your reply...
but i think u misunderstand about my VI...
below is a picture, i had make the column that i need to insert string become black...
if convenient, please take a look....
Jaxx 🙂
Message 3 of 19
(4,623 Views)
Right click on the terminal and select Create>>Property node.
Use the ActiveCell and CellBGColor properties to set the color.
___________________
Try to take over the world!
Message 4 of 19
(4,614 Views)
Hello
I think @ means the "non-header cell", top-left cell if colunm headers and row headers are active.
The only way I know to write in that cell is "customize control". Programmatically... I guess is not possible.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 5 of 19
(4,605 Views)
Actually, if you wire -1,-1 into the ActiveCell property it will work.
___________________
Message 6 of 19
(4,603 Views)
According to tst answers (not a color problem ;)), it seems that I'm not the only one to have misundestood your question!
It is not possible to write in the upper left corner of a table. A workaround would be to overlay a string above this part of the table. I have posted a few days ago a similar solution, to position a boolean over a table. See here :
http://forums.ni.com/ni/board/message?board.id=170&message.id=101841#M101841
Hope this helps !
CC
Message 7 of 19
(4,596 Views)
Oh. I get it now, CC.
It's just that I have LV 7.0 on this computer and I was working based on @'s second post.
___________________
Message 8 of 19
(4,590 Views)
Hello
Great, that works to change color, etc. Do you know how to write text in that cell?
I can´t write in it.
thanks
Alipio
Message 9 of 19
(4,589 Views)
You use the properties RowHdrs[] or ColHdrs[]. Each are 1D string arrays.
Message 10 of 19
(4,562 Views)
