anyone have a good pH meter vi?
I have only pH probe and reference probe.My pH meter can't send analog output. I need to create vi to measure pH value.How can i do that? I used AT-MIO-16XE-50 and labview6.
(3,094 Views)
Hello;
As long as the pH meter sends out some Analog voltage signal, you can use any of the DAQ example VIs Labview has.
A good one to refer to is the one called Continuous Acquisition and Chart(buffered).vi, which can be found at Search Examples->I/O Interfaces->Data Acquisition->Analog Input->Continuous Analog Input.
Just one more last tip, make sure to include the best range the input signal will have. By doing that, the DAQ board will apply the better gain in a sense the accuracy will be improved.
Hope this helps.
Filipe
(3,093 Views)
