Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
pop up a dialog based on a boolean
Sloppy
Member
01-23-2002
12:11 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I would like to know how I can pop up a One Button dialog based on a boolean i/p. I wish to pop up the dialog on a true and do nothing on a false
Thanks for any responses
0
Kudos
Message
1
of 3
(2,840 Views)
Reply
Re: pop up a dialog based on a boolean
Doug (CapeFl)
Active Participant
01-23-2002
12:32 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Put your 1-button dialog in a Case.
Wire your bool to the case.
If T - the dialog will run; if F - nothing will happen.
Good luck with it, Doug
0
Kudos
Message
2
of 3
(2,840 Views)
Reply
Sloppy
Member
Author
01-23-2002
12:49 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Geez, and so simple. thanks for the response
sorry for the (in hindsight) silly question
0
Kudos
Message
3
of 3
(2,840 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
