anyone help "comb filter"
first,i have to say sorry. my english is very poor.
there is my problem : i want to use comb design toolkit for my project.
i attach the vi file. how should i change my input like normal filter use "Waveform" input and not like ex:f0,Df,Ab.
anyone help? please!!
我英文敘述的很差,我想表達的是,
我要利用在LabVIEW內的comb design toolkit來製作comb filter,
我在下面有附檔,上方是comb filter的元件,下方是正常的filter,
而在輸入端方面有問題,我想要像是一般的filter是利用波形來輸入並且濾波,
而不是輸入參數f0,Df,Ab,Sample Frequency之類的來當輸入,
請問有人可以幫忙嗎? 謝謝
(3,047 Views)
The one VI you referring to defines the comb filter you want to use.  The inputs are as follows
Sampling Frequency = rate at which the data you are going to filter has been sampled at
f0 = The spacing of the notches in the spectrum
Df = the spectral width of the notches
Ab = the average depth of the notches
For example, you could make a comb filter to filter out 60 Hz and all harmonics of 60 Hz.  The parameters could be as follows:
Sampling Freq = 60000 Hz
f0 = 60 Hz
Df = 1 Hz
Ab = 20 dB
I simulated a 10 Hz Sine Wave with 60 Hz Square Wave noise on it.  Below are images of the block diagram and the front panel.
Randall Pursley
(2,886 Views)
