append new data in table
Hi...
I have some problem...mayb for those experts in Labview said this is a simple problem. How to append a new data in my table?Let say I want to change the string3 control to ee and string4 control to ff. Then it should add the new data in my table at the 3rd row. But when I run this program..what would happen is the new data will replace the data at the 2nd row. so plz help me in order to solve this problem..thanks...
(4,621 Views)
Hi gdah,
when you want to add to the table you should also do this... See attachment.
Usually you should try to avoid locals, here I only took it for demonstration purpose.
This code belongs into a loop using shift registers to do buffering and adding to the table...
(4,607 Views)
Hi..
I try to run the attchment that u give. but unfortunately there is no data display.the table become blank..any other option to solve this problem??thanks...
(4,602 Views)
Hi GerdW..
I have try again the attchment that u give. Actually it's working..thanks..
(4,600 Views)
